Fault 28 - Bridgeco boot fail
Posted by: skipper44 on 11 November 2013
I've hit the dreaded Fault 28 (Bridgeco boot fail) which seems to hit hard and not leave too many choices . . . cannot even connect to a network. Have  tried unplugging the mains and waiting etc, it worked a couple of times but alas no more. I think trying to select iRadio drove the final nail in. Will Uniiti 2 almost certainly have to go back to the mothership?
I've seen a few posts on the forum, anyone have the latest on this, or familiar with the last published chapter in that series?
Tears.
skipper.
Posted on: 13 November 2013 by Paul Stephenson
Hi, Not sure where you are but this needs to be solved by retailer,distributor or Naim, sounds like the streaming section is not communicating with the main board.
Posted on: 13 November 2013 by skipper44
Originally Posted by Paul Stephenson:
 . . . . this needs to be solved by retailer,distributor or Naim, . . . . .
Thank you, have called the retailer and about to do just  that.
skipper.
ps: luckily 20+ year old NAP140 has just been serviced and recapped! will pick it up in 'exchange'. hope it's partner 32 has survived the disuse in the meanwhile.
