Inky blackness - network tweak
Posted by: MangoMonkey on 16 November 2013
My network topology looks like this:
Synology in laundry room, to switch to Cat5 cable in the wall to cat 6 cable plugged into the streamer which is in my study. Using the media server in sinology.
I tried something this morning:
Synology in laundry room, to switch to Cat5 cable in the wall to Cat6 cable plugged into -> An apple router. The apple router gets hooked up to the PC that has dbAsset running. The apple router has a shielded screen cable running into the streamer. The dbAsset is pulling music through the network from the same nas.
The noise level has gone down a big notch.
Switching back to the older setup makes me feel queasy and annoyed.
I'm not entirely sure why this is better - theories:
a) The dbAsset is better
b) The cables are making the difference - Now I've got Cat 6 or better between the uPnp server and the streamer.
c) the streamer is doing less error correction/less work. My 2.4 Ghz PC is now doing the work of error correction caused by the cat 5 cable while reading files from the nas
d) dealing with much less cross talk etc. in the cables that are in the wall.
There doesn't seem to be any difference between dbasset pulling music from the nas vs from the local hard drive.
I'm not entirely sure what it means for the streamer in the living room - maybe I'll have to put a UnitiServe SSD right next to it.
