HiFace and OSX Mavericks
Posted by: SAT on 25 November 2013
If you use HiFace don't change to Mavericks!
I believe that a few contributors use Hiface, I recently changed OSX and now it won't work. M2 tech are aware of this problem and say they're working on new drivers but it's been a while since Mavericks came out.
In the meantime have any users moved on, and if so, to what, and is it an improvement?
Posted on: 26 November 2013 by DHT
I just bought the HiFace 2, plug and play and sounds perfect.
H
Posted on: 27 November 2013 by SAT
Thanks DHT, not an expensive route either! The first version has always seemed fine to me and seems to work well with my gear.
Posted on: 25 February 2014 by Westcoastman
I have experienced nothing but trouble in upgrading to Maverick. A complete disaster. For a start it comes with the more recent iTunes, which is not for me, as it does not have 'cover flow' and so I can't If my HiFace is plugged into the mac mini, iTunes will not even play a track. Also my Pure Music seemed to not get along with iTunes.....all in all the upgrade has been a total disaster and I am now trying to revert back to Mountain Lion and the older version of iTunes.
Posted on: 25 February 2014 by Simon-in-Suffolk
 I wonder what happened to 'it just works'?
Personally I find quality audio and macs just don't go together... But for graphics and photography it's a different story..
Simon
Posted on: 26 February 2014 by aht
HIFace 2 works without a plug-in, but HiFace I, Evo, and so on do not work with OS X Mavericks.  It's a big scandal in Italy, with accusations of defection, absconding with intellectual property, etc.   A fix is said to be in the works, but don't hold your breath.
Posted on: 26 February 2014 by SAT
I thought about buying a HiFace 2 but felt unhappy with m2 tech responses about my original HiFace so bought a Ciùnas instead. Have also moved from Pure Music to Audirvana plus. Would've liked to compare an Audiophilleo 2 but this wasn't possible and the latter by reputation only works properly with a separate battery supply and the Ciùnas has one built in. I am delighted with what I'm hearing.
