Hi All,
How does a "Mac & Naim Dac/XPS (using Audirvana)" set up compare (SQ wise) with using a Naim streamer such as NDX or NDS? I already have a good Dac and I wonder if connecting to my Mac would not be the better way to go...
Any one dare to share their experiences?
The experiences include both how the system is controlled, and the qualities and performance of the hardware. It's a multi-variable equation that cannot be solved for just "which is better -- computer or streamer."
A Mac Mini and a Naim DAC/XPS2 may be better than a bare XP5XS. It may not be as good as an NDS/555PS.
If you simply want to know which sounds better, computer into a dac via usb or upnp server into a streamer/player, the answer is . . . . . . . . . . . . . . . . . .
it depends.
And there has been much written here in the past year or two about this very topic. Nothing has changed since then, other than for Naim the intro of the Dac V1 which now gives Naim an entry in the usb dac market. And it's been VERY favorably reviewed here on the forums and in the press.
