Unitiqute 2 digital out
Posted by: Granthar on 27 November 2013
OK, I know I will get told RTFM and what a dumb question. Does the digital out on the Unitiqute 2 output all sources or only streamed content. I am guessing only streamed content as an ADC would have made it even more expensive?
Posted on: 27 November 2013 by jobseeker
AFAIK it will output the DIGITAL source that is currently being listened to at native sampling or 96Khz
Posted on: 27 November 2013 by Granthar
so the upgrade path that Naim list for it makes no sense as if you added a dac you would lose analogue and fm/dab capability.
It won't output analogue, I believe, but it will do FM because it is digitised internally within the radio module. At least that's how the 'Qute 1 works.
