Unitiserve Problems Again - sigh!
Posted by: Timbo on 28 November 2013
I will be dropping off my Unitiserve SSD to my dealers today. After a lot of small but irritating issues the unit has finally given up. Yesterday I was ripping some Cds and the database kept reporting that it was an unknown CD, which it has done several times. But usually I abort the process clean the CD which I think helps and then re-insert and everything is OK. By the way the internet connection was good and I was listening to radio paradise at the time.
This time it just did not recognize any and so I decided to reboot the unit. Usual procedure, touch light on front it starts to flash then after about a minute it shuts off, then I turn power off at the back, wait ten minutes or so then turn back on.
This time the unit started up with the front light flashing and hasn't stopped since. I can shut down the unit in the usual way but on startup it will not stop flashing so i can only assume it is a return to dealer situation. Anyone else had the continuous flashing light syndrome?
By the way this is the latest in a long line of issues:
Date and time reading 1753:01:01 on network shares
Up time starting to count backwards at roughly the 24 day mark
Dropping connections to network shares and stores for no reason
Taking 2-3 hours to scan music store of 1200 albums
I appreciate some aspects may be due to my network and not all the unitiserve's fault, but it's back to my squeezebox touch for the duration which I must say has been pretty much bullet proof.
Happy Days :-)
Tim
