Firmware version to be updated - ND5XS
Posted by: BENEDICT on 04 December 2013
Hello everybody,
In my case, since my streamer was bought in june 2012, I assume the version is actually 3.13.
Do I need to download and install every version (.16 .17.21.22)
Thanks a lot
Hello everybody,
Thanks a lot
+1. Since my streamer is working nicely, I am hesitant to update the firmware. Could I update in 2 or 3 versions time in one hit, or are the versions incremental ?
Hi Fretfan,
Thank you for expressing my request with other words.
Bump.
Perhaps you should ask Naim support or your dealer? I don't know the answer.
yes, you can do it all in one hit. I did several updates back. No problems.
Neil
Neil
Thanks Guys,
Just to clarify, for example, if my unit was 3 versions behind, I would only have to update with the latest release, and that would incorporate all the fixes in the previous releases.
I guess we are not patching, but completely overwriting the firmware, and the latest firmware would have been based on the immediate prior version..
please excuse my dumbness!
Fretfan
That's it. The latest firmware update will get you right up to speed.
Hi there,
Thanks for being crystal clear
My best regards
Benedict
Yes, no problems with streamers.
Not true with Naim's servers.
