unitilite display went off (new user)
Posted by: rafota on 09 December 2013
I have a brand new unitilite. There are a couple of issues that I need to iron out but one of them is that the front display went dark, I don't know how, and even a reset could not bring it back.
Is there some type of combination code using the remote to switch if on / off that I accidentally triggered? I read that another user (NDX) had a faulty display due to loose internal wiring, and a visit to the dealer took care of that. So that's my fall back.
Apart from the display, Unitilite sound works fine. (and apart from 2 streaming issues I will write  a post about)
Posted on: 09 December 2013 by Manu
You need to pay a visit to your dealer to test the unit and to help you with your network.
