itunes Qnap QPKG
Posted by: DF50 on 15 December 2013
Hi all,
iTunes has a qpkg for Qnap - can I use that some way as a UPNP server and control my music library to stream to my ND5XS,  using one of the many control point on my iPad, maybe even n-Stream?  I just find  Twonky horrible!
Thanks,
Posted on: 15 December 2013 by garyi
No.
itunes uses an apple proprietary system called daap, which is not upnp.
is there any qpackages called mini dnla, or dnla something? Try that
Posted on: 16 December 2013 by DF50
Thank you - no other dlna server!
Posted on: 16 December 2013 by garyi
http://minimserver.com/features.html
Posted on: 17 December 2013 by DF50
downloaded and taking for a test drive - look pretty good so far!...  Thank you!
