Unitiqute2 and Concept 20
Posted by: Sorren on 22 December 2013
I have finally joined the Naim family with a Unitiqute2 and a set of Q Acoustics Concept 20 speakers. A package deal at Sevenoaks. I had to travel all the way to Wetherby to get them but it was I good price and I'm very happy with the sound.
I had to turn trans-coding off on my Synology NAS so that the hi def stuff actually got to the Qute. It worked fine to send it to my Bluray but the Naim knows how to handle it raw not LPCM.
Now I'm having issues with BubbleUpnp not playing it's playlists in order or as just single tracks but I'm sure they won't be an insurmountable problems and so far I'm thrilled, I can't afford an Apple device for n-stream and I don't really want to aid Apple in it's quest for world domination anyway so ...
Posted on: 22 December 2013 by Pev
Hi Sorren - welcome!
If you are having trouble with Bubbleupnp it would be worth trying Bubbleupnp Server. This is free - I installed it on my pc and it made Asset much more stable. Not sure if it would work with a NAS if you don't also have a pc involved though.
Posted on: 22 December 2013 by Sorren
Hi Pev, Thanks. I'll look into it. It's strange though, Bubble never did this with the Bluray player I was using to stream before. Not had chance to look at it so far today as I've been out with the kids but I'll be trawling forums, etc tonight so fingers crossed.
Hi Pev
Just to let you know I fixed the problem with Bubble. I asked for help in this thread https://forums.naimaudio.com/to...p-users-able-to-help then figured it out. Needed a re-install.
