VTB Appliance Arrives Tomorrow:
Posted by: Russ on 22 December 2013
and I am eager to get started--and on the right track. I purchased the 4 TB version and for the time being, will back up to a laptop. Question is, I have a couple of hundred CD s ripped to Flac files. Should I just move them over to the VTB or is there an advantage to re-ripping them to the new unit? Thanks.
Russ
Hi Russ
just move 'em over - FLAC is FLAC and once they're ripped they are ripped!
Pev
Assuming you are talking about the estimable Vortexbox - welcome to the fold - as Pev says just copy your flac across.
Tog
Thanks, Pev and Tog. I have also seen advice elsewhere that ripping via dbpoweramp (as I am now to the laptop from which I will be moving the ripped files) sometimes results in superior metadata.
Best regards,
Russ
XLD works fine - if you get really stuck Music Brainz program Picard works well to sort out tagging.
Tog
Russ
You can also install bliss on bortex box, which is a good ol' tagger there.
Russ...Did it arrive, and are you pleased with it?
Hasn't arrived yet. Held up in Illinois by weather and rescheduled for today. Now rescheduled for 12/28.
Best regards,
Russ
As an update, the VTB 4 TB got caught up in the problems UPS had with regard to high volume and bad weather. I have now had it about a week and have had a chance to play with it. Mohit had said he preferred to build a VTB from scratch and I can definitely see how having some of the software you can plug into a PC built for that purpose might increase the flexibility. However, as the pathetic non-technical dork that I am, I preferred the turnkey solution So far--so good. With the help of some folks on the VTB Help Forum, I have it up and running and accessible to what passes for my home "network". I have ripped a few albums, but since most of my library is classical in nature, I have been moving files over that I had previously ripped using DBPOWERAMP. The only problems I am having so far relate, as you may imagine, to multiple-CD files, but I have been given a solution for that and will try it later--checking a box somewhere I have not yet.
The other interesting aspect of the box, about which I did not know, lies in its internet radio capabilities. I currently have access to this via the SU, of course, and through my second system in the living room--a nice little Marantz MCR-603. But I need a source of internet radio to plug into my third, "whole house" system--without running hundreds of feet of wire through the attic. So I am hopeful that I can figure out how to play the stuff from the VTB into the line-in that is the only way to get input into the whole house amplifier. That will come later.
Hope all have had a happy start to 2014.
Russ
