N-stream bug
Posted by: Kaver on 23 December 2013
Hello,
I have not seen others report this bug, but sometimes N-stream 3.6 on my Ipad get unresponsive. For example I presently can't pres the upper right hand corner button and sometimes and can't pres the input button. The bug was also there with version 3.5.
Posted on: 23 December 2013 by Kaver
Maybe I should have mentioned that the Ipad runs IOS 7.0.4
Posted on: 24 December 2013 by CSI_Basel
I also have the same problem. Its very annoying!
It did not occur on previous versions of nStream.
Posted on: 29 December 2013 by Kaver
When it occurs something also happens with the graphics in N-stream. Hope Naim will fix it soon.
Posted on: 30 December 2013 by engjoo
I currently have NDX connected to my SN2 with system automation enabled. The problem I am facing now is that intermittently, the volume control on the n-stream do not appear. What I need to do as a workaround is to disable/enable "show volume control" on the N-stream.
