as anybody tried accoutic form panels in there listening room ?
Posted on: 29 December 2013 by J.N.
You need to invest in a spill-chucker Mr Rushton. Or are you just enjoying a drink or three my good Sir?
Fabric covered acoustic foam panels can be very effective, used sparingly. I have some corner and wall panels manufactured by RPG from GRG Acoustics based in Kent.
John.
Posted on: 29 December 2013 by m.rushton
Ok thanks for that ,yes your right a drink as caused a spilling problem
Posted on: 30 December 2013 by Derek Wright
If you read the post with your brain and not with your mouth you would spot another typo.
