Export UnitiServe Playlists
Posted by: Naijeru on 29 December 2013
Has anyone black magicked a way to export UnitiServe playlists without having to manually reconstruct them? I'm migrating my music to a new NAS and I'd really like to avoid having to build the playlists from scratch.
Posted on: 29 December 2013 by Manu
If you copy the full Music store from one NAS to another using Explorer or Finder, the playlists will follow. They are in a folder named ''Playlists''
Alternatively, you can back them up with DeskTop-Client or N-Serve for MAC.
Posted on: 29 December 2013 by Naijeru
Hmm, no, they are not in a folder named "Playlists." Nor does the n-Serve software offer a feature to backup playlists. Thanks for the response though. The 'Serve is in the process of copying the library from the old drive to the new one; I'm hoping it is smart enough to recognize the songs on the new drive as belonging to the playlists (ala iTunes).
