Would you Adam and Eve it?!
Posted by: The Meerkat on 31 December 2013
Sorry about the rhyming slang
Would you believe it?! The grief that I've had with Twonky on my Qnap NAS, over the past week doesn't bare thinking about, posting various topics about it, and some very late nights.
As always though, I've received some great advice from forum members. Thank you guys.
Even after re ripping some CDs to WAV with XLD, then entering all the tags, by typing in each track, artist, etc...it still comes up on the iPad as 'Unknown artist', and 'Unknown album'? FLAC is not a problem, the metadata is all there.
Today, just out of curiosity I downloaded Twonky for iMac on a 30 day trial. It plays all my iTunes library perfectly. And...If I click on the 'info' button on N-Stream, it displays the little booklet, containing heaps of information on the album and artist, perfectly. However, I don't really want to listen to MP3 files through my lovely Naim system, although it is a means to an end.
What is it with WAV and metadata? I'd dump it, but I think it sounds just fractionally better than FLAC, very, very close though.
David, folks have been talking about the pro's and con's of wav for a while. There is no one industry standard way of putting metadata into wav files. If you want to keep ripping your own cd's but not on a UnitiServe, I really really recommend not ripping to wav. Rip to flac or Apple Lossless. Flac is probably most common.
Bart is right David - it is a known issue! If you don't want FLAC, AIFF is alot better to administer than WAV! I use AIFF, and I don't have an issue - the only reason I don't use FLAC, is because I was already ripped in AIFF, and I have had no real issues thank goodness! and AIFF is pretty much the same as WAV (Uncompressed).
I have a qnap NAS and I used Twonky until recently and decided to use a MAC Mini, and split up the UPNP from NAS. I had no real issues with current version of Twonky and AIFF with n-Stream - the only reason I don't use Twonky now is because I get bord Sometimes and figured I would try Asset on a Mac Mini!
seriously, as Bart has said - don't use WAV without the US. I am no expert but just from reading and trying I have figured that out! The only reason the US and WAV works is because the US used as separate and propriatory database for metadata!
Sorry, should have said Apple lossless, as Bart said (ALAC) or FLAC if not using ITunes, either way get off WAV and enjoy music!
Dave
Create sidecar *.thm files with MediaMonkey. Then you will see all info properly.
+1 Wat! And I use XLD also, nice touch Wat, u said it better than I did!
Dave.
"However, I don't really want to listen to MP3 files through my lovely Naim system, although it is a means to an end.
What is it with WAV and metadata? I'd dump it, but I think it sounds just fractionally better than FLAC, very, very close though."
David,
About what you said above - u don't want to listen to MP3's, but means to an end, but then go on to say WAV sounds fractionally better, than FLAC... The fractionally worse, that you hear, is still going to be better than the MP3's, right!
Just saying sir...
Dave.
Or use proper software that can read the fuller WAV spec rather than a tiny subset. WAV files actually have two ways of storing metadata, and many programmes use borh. The INFO tags which were created at the dawn of the format in the 1980s and more recently ID3 has been adopted like with AiF.
Asset, Minimserver, Media Monkey are a few UPNP DLNA servers that read full spec WAV files.
Simon
Simon...So are you saying that your suggested servers, will read the WAVs correctly, and not display Unknown album, Unknown track, on Naim streamers? If so, that would be good. I'm waiting for Mr Spoon to release dbpoweramp & Asset for Mac IOS. Apparently coming very soon!
DF50...You're right, it is going to be better.
Wat...Is AIFF, Apples version of MP3? I thought I read that somewhere. I agree about downloads. All my Hi Res downloads from Linn and HD Tracks are 96/24-bit FLAC. I also have all The Beatles remastered albums in 24-bit FLAC, and they all sound bloody fantastic!
Interesting! There you go David, try that first - you have a QNap NAS - Minimserver can be installed right on the NAS! looks like a very easy install. Just make sure you read instruction for qpkg install, and make sure you update your QNap with Java 6... Instruction on there web site.
And I leaned something else also...
Thanks,
Dave.
And Wat will probably answer this but, figured while I am online! No AIFF is nothing like MP3! MP3 is a fully compressed file that cannot be expanded or transcoded, a least to any benifit, AIFF is a full fledged Uncompressed file - much like WAV is!
ALAC is Apple's MP3.
Bart, I know what you're saying. I guess all I wanted, was to re rip my CDs to WAV, and for my ND5 XS be able to read all the data just as FLAC does. I've now come to the conclusion that that's not possible, at least not with my limited IT skills.
I haven't tried ALAC as yet.
What I am interest to know, the guys that are using a Vortexbox to rip, what files are they ripping to?
You dont need to try ALAC, MP3, or any other lossy format. Stay lossless with AIFF, FLAC, or WAV. AIFF is my choice, because it works well with Mac and PC alike.
Nick...I think I'm getting a bit confused. I thought ALAC (Apple Lossless Audio Codec) was a lossless format, or is that just Apple's interpretation of it?
Go with AAIF - if you like WAV, you will love AIFF, every bit as good, no difference, except easier... Really!
Vortexbox uses FLAC By the way! http://www.vortexbox.co.uk/index.aspx?pageid=438028
Meerkat - exactly yes, assuming the ripped files contain the correct meta data which using dBpowermap or Media Monkey they should.
BTW - AIF is the same file structure type as WAV (They had the same origin back in the 80's from the Electronic Arts Intrerchange File Format ). The other key difference is usually in the samples in that typically the bit order is reversed between WAV and AIF - though AIF can have various Data body parts including WAV ordered PCM - but some software might not be able to read it. I have not experimented with Naim to see which AIF data body parts it supports - other than the default subset used in iTunes.
Simon
You and Wat are correct. I confused lossless ALAC with lossy AAC. I settled on AIFF because it seems to be the most platform-neutral format. Meta data works well, and it can be converted to any other lossless format later, if necessary.
Sorry for adding to he confusion.
Nick
AIFF is apple's form of WAV
ALAC is apple's form of FLAC
AAC is apple's form of MP3
You see? Apple just don't want to conform to standards. There forms are just different, not better.
We call that "Vendor lock-in" and that's good .... for Apple's profits.
Hardly - only ALAC was proprietary - AIFF/AIF goes all the way back to the Amiga.
ALAC is now open source and AAC is no longer copy protected.
The jury is out over whether AAC is a better compressed codec at lower bit rates than mp3 - but to my ears they both sound rather crushed.
Tog
Tog - I tend to agree with you about AAC and MP3 sounding pretty similar but ultimately compromised and lacking finesse and detail at high bandwidth, but with low bandwidths (i.e. less than 192kbps) I find the nod goes to AAC.
Of course with both of these formats so much is dependent on the quality and setup of the encoder. I always use LAME for MP3. I have yet to find a good AAC encoder (though i haven't looked that hard ) - iTunes is very poor - to the extent I wonder whether it is done deliberately so you buy the AAC encoded files off iTunes portal instead.
Simon
Thank you everyone for your detailed replies, you've been incredibly helpful. It has certainly helped me understand music files, and their structure.
So, as a very last attempt to get Twonky to behave it self, I ripped a CD by Keane, using XLD, with the output format to AIF. The 'info' button on N-Stream displays all you need to know about that album and the band perfectly. But, and wait for it...Twonky displays the tracks in alphabetical order, yet again! ![]()
I think it's wine o'clock already
Happy New Year!
Flac that.
Flac that.
Sloop...after a few glasses of wine, that's exactly how I would describe this matter! ![]()
But check this out...I have just put 01, 02, etc before the track name on the XLD AIF rips, and to my shock, Twonky displays all the tracks in correct order with all metadata, irrespective whether I'm in Folder, Artist, or Album view.
The wine obviously did the trick! ![]()
Tog
You are complete right Tog.
AIFF is definitely not a proprietary Apple format, nor is it Apple's version of WAV. In fact WAV implementations are proprietary and often lock you in because of the way metadata is handled. AIFF is and always has been an open standard. It is based on the original IFF format from EA developed for the Amiga computer.
AAC sounds better to me than MP3 if the bit rate is the same. I only use these formats if I am unable to get a lossless copy. Neither is format I like, but better than nothing.
ALAC is now open, but was an Apple format. ALAC can be converted to FLAC or AIFF without loss of metadata or sound quality. It can also be converted to WAV, but you may lose metadata, artwork, lyrics and ... Well I just avoid WAV.
If Naim had chosen AIFF rather than WAV then it would be much simpler to move files from a US to another UPnP server, but perhaps they didn't want to. Still now the US works with FLAC surely that will become the preferred route. This would make the need to use a proprietary Microsoft database a thing of the past. I was always disappointed Naim chose a proprietary Microsoft OS to create a closed system. However, I have always preferred open standards with open APIs even if I am predominantly an OS X user these days.
For me, the sound quality is the same whatever lossless format I use, but AIFF works really well. I think FLAC would work just as well if my home computing environment was not almost entirely Apple. Even if I had a PC I would not use WAV. I really don't see the need to store music as WAV as if you have a streamer that prefers music in WAV format then many UPnP servers can transcode on the fly. The only format that appears to promise better sound and I am able to play is DSD.
Personally, i like my system to just play music irrespective of format.
I really hope whatever format you use you can get it to display sensibly and play: music is much more important than formats or silly arguments between computer companies.
A very interesting and detailed insight to the various file formats. Thanks Wat...As you say, and most people would say, we are here for the music! And really, we are all playing for the same team. Who on earth would spend thousands of $ € £ on Hi Fi, if they didn't love music.
The good thing about this forum, is that it's quite educational. I didn't have a clue about streaming a year ago (Still don't
) but over the past few months I have gained a great deal of knowledge, provided by other forum members. Thank you guys.
It is evident on my particular set up, others may have a different experience, is that FLAC works, and sounds great. But AIFF appears to be the only format that sounds great, but more importantly, shows all the correct metadata in Folder, Artist, and Album views on Twonky?
Cheers to all...
