Playlist empty
Posted by: DomTomLondon on 06 January 2014
Hi guys, sorry if this has been posted before.
I love using nStream to add songs to my favourites playlist. My wife also has a playlist with all her favourites. This has worked fine for us for quite a while, but today when I went into my playlist I found it empty. I tried her playlist and it was fine. Then a few hours later her playlist has also become empty. I have not changed any settings and the NAS is still connected and playing music just fine. Any ideas? Before I go through 700+ albums to re-create our playlists...
thanks.
Posted on: 07 January 2014 by Maxwell
Hi DomTom,
I thought I had the same problem, but by going back through to the server I had the option of Twonky or Naimserver. I had saved my playlists on Twonky, but the i-pad remote had switched to Naimserver. When I selected Twonky again, my playlists were there.
You may of course have a different problem, but finding this saved my on New Years eve.
Posted on: 07 January 2014 by DomTomLondon
Thanks Maxwell, unfortunately I only have the one server on my synology NAS to choose from.
I've tried restarting the app, but the playlists are still empty.
Posted on: 07 January 2014 by JohnF
I have the same problem in that i have saved playlists then lost them. Similar setup to yours using synology nas with my partner using her ipad on same itunes account. I do wonder if it may be due to conflicting automatic cloud backups from the ipad. I may turn of the cloud backup on my partners.
