Incorrect Pasword ?????
Posted by: Blueknowz on 09 January 2014
I use the same password on both my Laptop & main PC for this forum ,but when I try to sign in on my iPad it tells me it is the wrong password ???? any Ideas
Posted on: 09 January 2014 by Richard Dane
Caps lock on?  Correct username?
I'm afraid I have no access to anyone's password here.
Posted on: 09 January 2014 by Chief Chirpa
Auto-Capitalisation maybe? (If there's a . or a ? or a ! in your password, the next letter is capitalised.)
It's on by default, though can be switched off under Settings > General > Keyboard
Posted on: 09 January 2014 by Andrew Porter
I had the same problem. My solution was to delete the app and when it was re downloaded the password worked again. Worth a try!
Posted on: 09 January 2014 by Blueknowz
That's fixed it chief thanks
