cat 6
Posted by: dayjay on 19 January 2014
Just spent two hours fitting cat 6 to replace the powerlines I wss using. Was it worth the effort?
Posted on: 19 January 2014 by winkyincanada
Yes?
Posted on: 19 January 2014 by dayjay
Strangely enough I think yes, slightly improved claritfy, bass and soundstage. Wether thats because I've removed the powerlines, dressed the cables or wishful thinking I don't know but at least I don't have to worry about it anymore!
Posted on: 19 January 2014 by garyi
Not sure what hifi you have but what you will benefit from is reliability.
Posted on: 19 January 2014 by Simon-in-Suffolk
And of course assuming you have stopped using the powerlines, your RFI pollution will have dramatically reduced, and that can only be a good thing for hifi.
Simon
Yes, the power lines are a thing of the past ![]()
Posted on: 20 January 2014 by dzambolaja
what is the length?
Posted on: 21 January 2014 by dayjay
30 metres
