no broadband
Posted by: longmanjon on 24 January 2014
hi all, i am moving house next week and BT have decided they cannot connect us up until Feb 24th, as its also a new build.
The problem is that all my music and movies is on my NAS, how can i still stream?
i have some spare routers from sky, is it possible to just use one as a switch and still be able to stream to my qute or TV without any external broadband/phone connection?
Posted on: 24 January 2014 by greentg
The short answer to your question is yes. as long as your streamer and NAS are connected to the powered router ie. you have an internal network, you will be able to stream. It goes without saying that internet radio will be a"no go" however
Posted on: 24 January 2014 by longmanjon
thats great many thanks.
yes the NAS,tv,qute would all be connected to the router.
In which case al should be fine.
Posted on: 24 January 2014 by Bananahead
Actually if it's a new build I hope you have lots of ducting so that you can put in whatever cable is needed in the future.
