Tellurium Q black or NAC A5 speaker cable?
Posted by: TigerJWW on 01 February 2014
Just purchased a Superuniti and Neat SX2speakers. Still undecided on which speaker cable is best for this set up. I've listened to both, but would welcome thoughts from anyone who has used either cable. I'm looking to purchase 2 x 5m lengths.
Posted on: 01 February 2014 by hungryhalibut
I use Chord Odyssey with my SuperUniti, which works really well. So I'd recommend that, which may or may not be helpful.
Posted on: 01 February 2014 by Scooot
Hi,
I use chord epic twin speaker cable.i agree with HH, chord works well with naim.
Scott
Posted on: 01 February 2014 by MDS
I use Tellurium Q but the 'Green' which is a fair bit more expensive than 'Black'. However I know some on here use TQ Black with their Naim amps.  I've heard one system with that configuration and it sounds very fine indeed.
Posted on: 02 February 2014 by heihei
I demod some black vs my naca5 and found the black was more transparent but sounded a bit too thin. I preferred the slight loss in clarity but fuller body of the naca5.
Posted on: 31 March 2014 by Evowai
I have replaced my NACA5 with the TQ Black for about 2 weeks, I preferred the clarity and wider sound stage from the TQ Black, I hear more details at the higher end which I didn't hear from NACA5 before, I didn't find I have lost much bass, maybe it's the PMC's ATL doing it's trick
Wai
