Goodbye WAV, hello FLAC
Posted by: hungryhalibut on 20 February 2014
Since getting my UnitiServe last year, I have been ripping CDs in WAV. With over 2,000 CDs, the Serve was filling up fast, and I have no desire for extra music stores. I was also concerned over some of the tales about Naim streamers struggling to cope with UnitiServe WAV rips if they are streamed direct from a NAS. I had visions of the Serve conking out and my NAS backup being unplayable, or at best a bit of a dog's breakfast.
Anyway.... I set the Serve to convert all the files to FLAC; a process that took about four days. I tried streaming them in FLAC, but the sound was a bit weedy compared to the WAV versions. So the Serve is now set to transcode to WAV on playback, and to my ears at least, I can't tell the difference between WAV rips and FLACs transcoded to WAV.
Once everything was converted, I simply turned on the NAS, ran a differential backup and all the WAVs were magically replaced by FLACs. And now, the file library is only 0.6TB, compared to the 1.4TB that is was previously.
The Serve now rips as FLAC - incidentally it actually rips in WAV, and then converts to FLAC. The whole thing has worked faultlessly, apart from about ten CDs that won't convert, due to metadata issues that I can't identify.
I'd suggest to anyone with a UnitiServe that is filling up that they try converting to FLAC, and then transcoding back. You can try just one album and see what you think before committing yourself. Just go into the album list in the DTC, right click on the one you want, and select convert to FLAC. Easy peasy.
Posted on: 20 February 2014 by Scooot
Hi,
I hope someone can enlighten me on this subject.i can understand if a mp3 file is converted to flac it will not sound as good as the cd ripped direct to flac as the loss converting to mp3 has already accured.
Therefore how do people report that converting flac by fly on the wall to wav improves sq as flac is totaly lossless.
Scott
Posted on: 20 February 2014 by garyi
God knows, to my ears its identical.
But wheres the fun of the audiophile without a hierarchy? My ears simply are not golden enough.
Posted on: 20 February 2014 by Bart
Originally Posted by Scooot:
Hi,
Scott
Hi Scott.
Two different "theories" at work here.  With your mp3 example, clearly info has been lost when ripping to mp3 and that info cannot be re-created out of thin air by 'converting' to flac.  But with wav and flac, no info has been lost; it's all still there.  BUT the theory goes that the cpu in the player has to work harder to unpack flac, and that that hard work can lead to 'stuff happening' that degrades the sound.
Posted on: 20 February 2014 by hungryhalibut
I wasn't intending to open up a WAV/FLAC debate, merely recounting my experience. I can clearly hear the difference, and I have no hearing above 4k, or so the audiologist told me, so I certainly don't have golden ears.
My experience is the same as HH -- I cannot hear any difference between wav rips and flac transcoded to wav.  So I'm happy with all flacs in my MQ folder!
Posted on: 20 February 2014 by DavidDever
Backup your WAV library first, then change the transcode settings (as this may take a while).  You then have the luxury of a WAV library backup from which you can easily compare, in real time, FLAC transcoded to WAV vs native WAV from the UnitiServe.
Different streamers provide different results (I've had the luxury of a few manufacturers' models 'round these parts lately); if the transcoded FLAC sounds perfectly acceptable, it may end up being your best bet from an archival perspective.  As always, your mileage may vary.
I'm planning on using my transcoded FLACs with Asset UPnP and / or MiniServer on a spare NAS or two; that said, I have no idea yet as to the FLAC compression level used by the UnitiServe (which still rips to WAV as an intermediate step, then transcodes to FLAC)–I'm assuming FLAC Level 7 or 5.  (I may choose to transcode this to uncompressed FLAC as well, just to see....)
Well, I'm WAVless. The master copy in the Serve, the backup and the Raid copy are all FLAC now, apart from the 10 that got away.
Posted on: 20 February 2014 by rupert
Hi I just use a PC and a nas drive to flac saves me a lot of money sounds fine regards.
Posted on: 20 February 2014 by charlesphoto
I transcode with LMS on the Vortexbox from Flac (level 5) to PCM on my UQ. PCM sounds better, but it's subtle. But considering the gobs of $ people spend for subtle upgrades, checking a box on the server cost absolutely nothing.
Posted on: 20 February 2014 by Simon-in-Suffolk
Yep, I transcode on the fly from FLAC to WAV here, and sounds identical to streaming WAV. In fact I did a Wireshark trace sometime back, and could see the WAV data being transferred by the UPnP server whether transcoded or played natively indeed was identical... Well at least for the first sequence of packets.
indeed it is the processing of the FLAC data by the network player to extract the PCM that does indeed cause the sonic side effect. I can also hear a less obvious difference between different UPnP servers that use different TCP window sizes, and therefore it would appear a  different frequency of ACK processing.
So far I have found the Unitiserve and the Raspberry Pi (subjectively) sound best.
Simon
Hi simon,
I currently use twonky on a qnap ts119 with all files converted to flac sent to my nd5xs.
Are you saying even though I would not know how to go about setting up the transcode I would benefit converting to wav.
Scott
Scott, in my experience (and seemingly of the experiences of several others on this forum) then yes.
It does cost nothing to transcode, assuming your UPnP server supports it, so if it makes a positive difference then great... If not you can switch transcoding back off.
Simon
Hi simon,
Thank you,I will certainly give it a go.i will though have to do my homework as I am am not sure how to set this up .
Scott
Simon
Simon - you are losing me...... What are PCM, TCP and ACK? My mum used to put TCP on my cuts and grazes when I was small, but somehow I suspect it's not that.....
Posted on: 20 February 2014 by Hook
HH -
TCP stands for Transmission Control Protocol.  It is one of the core protocols used for network communications, and is responsible for things like flow control and error checking.  It's actually part of a seven layer cake known as the Open Systems Interconnection model, where it assumes responsibility for layer three processing.  Layer one is the physical interconnect, layer seven is the human interface, and in-between is all the code that allows your US to talk to your SuperUniti.
It's called an ACK protocol because part of it's bi-directional processing is the positive acknowledgement of data frames that arrive without errors.  Other protocols are silent in this regard, and only negatively acknowledge problems (and are called NACK protocols). TCP has to deal with the chaos of layer two processing, where frames arrive at varying rates and even occasionally out of order.  Basically, it makes our network connections...reliable.
Simon has long posited that by correctly setting the frame size for TCP, network processing can be more efficient.  When network cards do less work, they generate less noise, and they have the potential for producing better sound.
Or something like that.
Am sure 'da man will be along shortly to explain further!
ATB.
Hook
PS - And oh yeah, under the logical wrappers of WAV or FLAC lie musical data.  That data is in a format called PCM, or Pulse-Code Modulation.  It's a method used to digitally represent sampled audio signals.
Hook- thanks - perfect reply.
Simon
The student blushes at the praise of the teacher...
Thanks Simon!
Posted on: 20 February 2014 by Jota
Hi,
Scott
In the White Paper on the NDX from 2010, Naim writes:
"Naim’s UPnP™ servers deliver the uncompressed audio data ripped from CD using the Naim ripping engine to ensure the best quality reproduction. Uncompressed audio data will always give better results than compressed. Even lossless compression may not reproduce audio with equivalent quality to the uncompressed original as the processing required to uncompress the data increases the computational load. This raises the power supply noise floor, which detracts from the sound quality."
Posted on: 20 February 2014 by mikapoh
I didn't know when Simon has become a professor in audio.
Posted on: 20 February 2014 by DrMark
Posted on: 20 February 2014 by Jan-Erik Nordoen
Hey, that's my line
Posted on: 20 February 2014 by GregU
The reason WAV sounds better than FLAC, even if it's FLAC converted to WAV, is the same reason as music sounds better if your amp sits on a fraim, as opposed to being on a shelf from pottery barn.
Posted on: 20 February 2014 by joerand
Greg,
Choice between Fraim vs Pottery Barn can be a matter of cost. Doesn't really apply with WAV vs FLAC does it?
Posted on: 20 February 2014 by GraemeH
Simon
I've footered about with 'My Book Live' but cannot fathom this 'transcoding' lark at all.
hmmmm...
Now there is a thought, perhaps time for a career change.....
