iRadio settings - add stations
Posted by: Sakis on 25 February 2014
Hi! is there anyone who can help me to understand how Naim Radio Guide works?
i try to add some stations and i can't understand how to add them? the stations are displayed in the list of Radio Guide, i choose them and add them as favorite, but can't displayed to my unitiqute!
also i can't understand why asked me to create groups with favorites, and how can i rename them..
mixed-up and frustating.. thanks for any help
The purpose of add stations function in vTuner web interface (NaimRadio Guide) is to add stations which are not listed by vTuner. All the station listed are available in your device. If you want to save your favourite stations you can utilize the preset function included in n-Stream (or in remote control). There is room for 40 stations (sometimes that is not enough I know, mine is full).
You are not alone in this issue. There is another recent thread about this matter:
osprey, thanks for your reply,
the problem is that i m searching for some stations that doesn't listed in my device, but are listed in vTuner, that's why i m trying to add these stations...for example my device listed 406 stations but the vTuner listed 438 stations, i dont understand why these 32 stations aren't available at my device, also i can't add them with the function of vTuner, because as you said the purpose of NaimRadio Guide is to add stations which are not listed by vTuner.
Ok, I understand. Which stations you are looking for? Give one example and I can try if I can see it in my Uniti.
| Imagine 89.7 FM | Thessaloniki Greece | Classic Rock | MP3 64K |
| Pepper 96.6 FM | Athens Greece | Pop | WMA 80K |
Pepper.... http://captainjack.live24.gr/captainjack9660
I did not find these either. However, there is a possibility to include these in the added stations using a work around. This is what I did:
- I searched the stations and pressed the green play button. This opened Windows Media Player and station started to play. In the right hand side panel I right clicked the item (under now playing) and selected the properties in order to get the stream address.
- I went into vTuner web page and clicked the arrow in the section My Added Stations (above the search).
- The following window opens:
Enter the information for the station you would like to add.
The station will be immediately added as one of your favourites.
| Station Name | Imagine 89.7 FM |
| Desc | |
| Station URL | http://myradio.naimaudio.com/pls/pls25004.m3u |
| (for example, http://62.168.116.98:8000/dsp1) | |
| Location | Thessaloniki Greece |
| (for example, Canada, Germany, Buenos Aires) | |
| Genre | Classic Rock |
| (for example, Classical, Dance, Rock) | |
| Type: | MP3 |
| Bitrate | 64K |
4. I filled the station info (including the station URL I got from WMP) and pressed the arrow.
5. It appeared in the home page as following:
My Added Stations | |||||||
6. It can now be found in the “Added Stations” listing in n-Stream (or using the remote control)
I know this is a bit difficult way to do it but at least you can then listen to these stations through your device. (The URL for Pepper 96.6 FM is http://myradio.naimaudio.com/pls/pls22757.asx)
osprey, thanks a lot for your time and help!
nevertheless, it is weird why these stations are not listed in my device...
