ScaleGuard Q
Posted by: BigH47 on 22 March 2014
Our local water company Thames is promoting this product ScaleGuard Professional, it looks like a wire coiled around I assume the inlet water pipe , a powered box. Only £96 which is good if it works of course.
It claims to condition water remove even existing scale, guaranteed to work or money back.
Cynical me says how long to prove or not that it's not working.
We have slightly hard water some kettle furring and lime scale.
Does anyone have any personal experience of this device?
here or http://www.scaleguard.co.uk/
PS how do you put a URL under a word in a forum post?
Posted on: 22 March 2014 by Tony Lockhart
To put the URL under a word, I think I used to highlight the URL as if I was going to copy, then just type the required word.
I don't do it now, as I don't think it's possible on iDevices. I'll try it!
Posted on: 22 March 2014 by BigH47
Thanks Tony
It sort of worked you have to double click the h.
Posted on: 22 March 2014 by mista h
Looks like its gone up in price in the last hour. The scaleguard site says its £118. That said if it works i would be very interested....IF IT WORKS !!
Mista H
£96 special offer from Thames Water. Yes if it works but as only the manufacture and TW to endorse it so far the jury is still out.
Posted on: 23 March 2014 by kevinrt
I bought this one from B&Q several years back. I believe it has reduced the amount of scale in our kettle but haven't really done a proper 'before and after' test.
http://www.diy.com/nav/fix/plu...271770?skuId=9281470
I looked around the internet at the time and there were a few to choose from. I think I chose this one based partly on price and partly on the proximity of the nearest B&Q store.
Kevin
Posted on: 23 March 2014 by Bananahead
If it works then why aren't they fitted at the pumping station?
Posted on: 23 March 2014 by Jota
So if it's stopping all this crap sticking to your kettles, where do you think it's ending up?
I think I'd rather have it in my kettle than in my body.
Dunno if this is relevant or not.
http://www.chem1.com/CQ/aquacrack.html
http://www.chem1.com/CQ/magscams.html
http://www.chem1.com/CQ/catscams.html
Posted on: 23 March 2014 by Mike-B
I fitted one many years ago & after a number of months was not convinced that it worked that well. The chalk in the kettle still built up but maybe it appeared to be less. The devise stopped working after about 5 years & I removed it, the kettle chalk does not appear to be any worse.
My question is why do Thames Water & Brit Gas et al offer proper filters to install on water & heating systems if this gadget works.  I suspect its a bit of a marketing gimmick (for want of a better word) to make a few bob.
Posted on: 23 March 2014 by mista h
Have to say these posts have got me thinking !! One thing we do use in our kitchen that DOES make for better tasting water is a Brita filter jug,which SHMBO changes the filter 1st day of every month.
Mista h
Posted on: 23 March 2014 by BigH47
Good points guys, I'm sure I can find some thing else to spend a ton on, a "new" not,  LZ album maybe?
I was going to say we will continue with the Brita jugs for now. mista h just reminded me.
Banana man has a good point.
Mista h
Brita filter jugs will work on your drinking water but obviously won't affect the deposits in your boiler, shower, washing machine etc. So if you live in a hard water area you would need some other solution to deal with those. The systems that involve passing the mains water through some sort of salt solution work, but involve a lot more expense and installation.
Kevin
Posted on: 23 March 2014 by Steve J
Thames tap water has been shown to be better than most 'spring water' in taste tests. Hard water generally tastes better than soft, presumably due to the minerals. The only way to stop furring with limescale in hard water areas is to fit a water softener, but have a direct mains feed to the kitchen for drinking water.
Posted on: 24 March 2014 by hungryhalibut
We used one for several years. The scale on the tiles in the shower all came off, but black deposits built up under the rim of the loo. As soon as we turned it off, the reverse happened.
Anyway Howard, if you want it, you can have it. It still works as it always did.
Posted on: 24 March 2014 by George J
Limescale is only a bit of lime.
Drinking water has contained lime since the year dot.
Not a problem worth spending money on solving, IMHO.
ATB from George
Posted on: 30 March 2014 by J.N.
I have very hard water here and used to piddle about (not literally!) filtering it with a Brita thingy. Now I simply descale the kettle with a sachet of 'Oust' about once a month. I'm not convinced about the complete efficacy of those devices you're asking about Howard.
And as George has intimated, 'hard' water has alleged benefits for consumption.
"Drinking hard water can reduce your risk of osteoporosis because of the calcium carbonate in the water. For this to be true, however, a good supply of vitamin D is necessary in the diet since it helps your body absorb calcium. A 2004 Finnish study suggests the minerals in hard water can help prevent heart disease, as well."
John.
Posted on: 30 March 2014 by Michael
Because of the hard water in East Anglia I decided to have a proper water softener fitted in my brand new house which works with block salt. It feeds the whole house supply to taps and the central heating system. Although you can drink the water from it, for health reasons I have a dedicated filtered water drinking tap on the kitchen sink as well as the softened water hot and cold taps. Also the exterior garden tap by-passes the softener as the hard water is better for the plants.
After four and a half years, not a hint of lime scale anywhere, reduced levels of detergents, no need to put salt in the dishwasher and  gleaming sinks and taps and shower screens... well worth the money in a new build.
Posted on: 30 March 2014 by naim_nymph
Michael,
I'm having a new kitchen put in very soon, and a water softener is high on the list of new improvements.
The water around here is so hard it can put a nasty taste in tea or coffee within 3 days from the kettle furring up, and after 3 weeks the kettle is totally clogged.
I've never known an area so bad as this, the Brita filter jug is a must around here.
Can you recommend a make or type of softener that works really well please?
Posted on: 30 March 2014 by George J
Dear Debs,
Permutit, now a Seimens subsidiary company, make the best.
ATB from George
Originally Posted by George J:
Dear Debs,
ATB from George
George,
are they the people who produced the heavy water at, Vemork
Dear Debs,
The plant was owned by the Norsk Hydro, but no doubt that Seimens provided much of the high-tech equipment.
Seimens provided the torpedoes that Norway used in April 1940 to sink the Blucher [loss of 900 Gestapo and others] on its way past the Oskarfort, opposite Droback in the Oslofjord, in the Nazi invasion of Norway This sinking was only ten Km from where my late grandparents lived.
Seimens also made the original electric stage lighting in the Royal Opera House, Covent Garden, fitted before WWI.
They seems to have been and still are a very technically advanced company really!
ATB from George
Posted on: 31 March 2014 by Derek Wright
Whatever make of water softener you choose, ensure that you will have easy access to the device to replenish the salt be it blocks or nuts. Some makes display the device as being suitable to be placed in a cupboard with out considering the difficulty of tipping a sack of salt into the device.
If you can arrange to have an un-softened supply for drinking you might find the taste more pleasant.
Lots of disagreement as to whether softened water is harmful, or tastes. YMMV
Posted on: 31 March 2014 by Bruce Woodhouse
In my experience the issue of how it tastes is not hard vs soft. Our water is exceptionally soft. It comes from a spring supply. It does not taste of chlorine or like it has already been swallowed and peed out 57 times. My parents in Essex have hard water. It is utterly foul for the opposite reasons. Tea made with it is undrinkable.
Bruce
Posted on: 31 March 2014 by naim_nymph
Water softeners are commonly installed under the kitchen sink which is usually where the water supply enters the home [and the stop cock].
It’s also common practice to exclude the cold tap on the kitchen sink so drinking water is excluded from the softener so i know my Brita water filter jug will remain in use.
Shame it has to cost so much though, it looks like around £600 to fit a softener, and up to £100 a year to spend on the rock salt.
Should get a discount on the water rates for that : (
I think it is difficult to generalise where the water softener is located - I have seen them in the adjacent garage, in the downstairs WC, in a cupboard in the utility room.
As long as the location is frost free and accessible from the top and close to the house water inlet then that is all.
