UnitiServe Music Library Column Headings
Posted by: deepinsight on 28 March 2014
Looking at the Music Library, Albums display on my UnitiServe from the desktop client, there is a column named, "Low Quality". All of the albums have this set to "Yes".
When looking at the properties of the album tracks, they are all .WAV files.
What then does Low Quality = Yes mean in this context?
Posted on: 29 March 2014 by GerryMcg
I believe you will find that all those rips are located in the LQ folder rather than the HQ, folder. A month or so ago I was experimenting with the options in DTC  and under tools>System settings>Ripping/Encoding I changed the MP3 parallel library >Bit Rate to yes. The album I ripped after this was also shown as LQ and was in that folder. I then discovered that the CD was also in the MQ folder, so with the Bit Rate setting on yes you get two copies of the album, one in MP3 format, although the DTC does not seem to show the MP3 version on its list of albums.
Gerry
