Projector for business use?
Posted by: Tarquin Maynard - Portly on 03 April 2014
Might just POSSIBLY be used at home with Sky and DVD...
Don't want to spend a fortune but would like to buy a projector, for use in the first instance at a benefits fair we're running. So, needs t be bright enough for daylight use...
Any suggestions, Groovers?
TIA
Mike
Posted on: 04 April 2014 by Tarquin Maynard - Portly
Oh well.
Posted on: 06 April 2014 by Tarquin Maynard - Portly
Got a free one.
Which is nice.
Posted on: 26 May 2014 by ewemon
Saw this too late as I could have recomended one.
One thing I will ask did you check on the life is left in the bulbs as they can either be difficult to get or very expensive to replace.
Some projectors are able to tell you how much bulb life is left others aren't.
