Bargain NAS enclosure that is on the OK list...
Posted by: RoyleBlue on 16 February 2011
...please delete if I'm not allowed to post this though!
http://www.dabs.com/products/d...-enclosure-49GV.html
Posted on: 16 February 2011 by DavidDever
I highly recommend its sibling product the DNS-321, which lacks superfluous features such as USB Printer Sharing but is quiet, even cheaper, and seems to be a slight bit faster using the NAS Simulation Utility.
Posted on: 02 March 2011 by balma01
have 2 2.5 HDD. Do you think Is it possible to install them inside a dns-321 or dns-323? maybe with a device that' trasforms' the 2.5 in a 3.5? Otherwise, there are some 2.5 enclosure that are compatible with a uniti?
Posted on: 02 March 2011 by pcstockton
get whatever DD says. He knows his shit.
Posted on: 03 March 2011 by RoyleBlue
Went with the DNS-323 - delivered for £52! Now, which 2 TB HDD's do I get? Seems about £60 per HDD is the going rate for WD Caviar Green or Samsung F4.
Posted on: 03 March 2011 by Tog
That would be a great epitaph ... "He knew his sh**!"High praise indeed
Tog
Posted on: 03 March 2011 by DavidDever
There are a variety of compliant mounts that can be obtained to mount 2.5" notebook hard drive mechanisms into a chassis designed for 3.5" drives.
I've heard 2.5" inch are quieter any truth in that?
Tog
Tog
Excuse my ignorance / lack of knowledge David, but why would 2.5" drives be better?Posted on: 03 March 2011 by DavidDever
I'm not sure they would be, aside from reduced mechanical vibration-the MTBF is much shorter.
Posted on: 03 March 2011 by balma01
OK, I'm looking for a DNS-323 because here (Italy) the 321 is impossible to find. What about the upnp server, does it provides dynamic playlists (last albums added, last album played...) ?
