Naim streaming system
Posted by: Iscb2014 on 07 April 2014
Hi
We used to have a linn streaming system Klimax DS / Kontrol / 350A speakers and in two other rooms Sneaky DS. The system all worked very well until a lightning strike which has destroyed large parts of the system. Hopefully insurance will cover the replacement cost of the system which could be a very significant sum which could allow us to purchase a Linn Exakt system and replacement Sneaky DS's Rather than just go ahead with that we're trying to understand what alternatives are out there that we should at least consider.
It's not clear to us how the Naim system works, specific questions are as follows;
1) what components would be required for the complete reference system ? Are they all available from Naim ?
2) can the system use an existing music server (we use MinimServer) running on a NAS or does it require some proprietary kit ?
3) what components are required to add other rooms ?
4) can all the connectivity between components be run over the standard Cat5e cabling we have installed across our home (wireless is not good due to the thickness of internal walls) ?
4) is there in-built functionality for the reference system to "share" the tracks it's playing with the other rooms ?
5) does internet radio come as standard ?
6) is an iPad and iPhone app available for control of both the reference and secondary systems ?
7) does the system require a dedicated network or can it share with normal PC and video traffic ?
8) without being religious why is the Naim approach better than the Linn approach (we know this is subjective but interested to hear views) ?
9) does the system support 24bit at high sample rates ?
