Search for hi-def music on unitiserve SSD?
Posted by: Rankinnz on 11 April 2014
I have a superuniti that I am now using with a unitiserve SSD. All music has been ripped and all is well. Is there any way of searching for hi-def music via nStream in this configuration? I have all the upnp music view settings on the unitiserve checked on. I have previously used twonky (QNAP) and minimserver as the upnp "servers' and they had the capability (the former by folder search).
Posted on: 11 April 2014 by Manu
You can browse by device and point to your HiDef library's folders.
Posted on: 11 April 2014 by Rankinnz
I can browse by device on ipad (not iPhone), but it doesn't give me a folder view. I get a slightly reduced list of options - album, artist, genres etc. There is nothing new or different via this option.
Posted on: 11 April 2014 by hafler3o
Give all your hi-def download albums etc a new name ie. add (24 bit) to the end of the album name for instance, then it's easily located.
Yep, I guess that would be a way! I had previously always stripped such nformation off the album details, but that may be what I have to do. It's not ideal, I'd much rather be able to search by the quality of the recording, but that's obviously not available just yet. Thanks.
