nStream App slow
Posted by: Chris Bell on 04 May 2014
In recent months I have noticed the nStream app is running slow on my iPad mini.  There's a long delay between hitting the selection and the app responding.  Annoying as it used to run fast.
Any suggestions on how to get nStream to be more snappy?
Posted on: 04 May 2014 by Jota
Maybe an uninstal and reinstall. I know that's more a Windows trick but may be worth a go.
Posted on: 04 May 2014 by Bart
A fine suggestion!  First I would start by 'killing' all apps -- double-click the home button and kill all apps. Then do a hard re-boot of the iPad.  See if that helps.  This is good practice in any event.
Posted on: 04 May 2014 by Chris Bell
I've done all that... still very slow responsiveness.  Is this an iOS7 issue?
Posted on: 04 May 2014 by LarsDK
Do you have same issue w other devices? If yes maybe more network problem (thats what i had)
Posted on: 04 May 2014 by hafler3o
Mine does this from time to time, it just seems to take a little snooze break!
Posted on: 04 May 2014 by GraemeH
Not in my experience Chris.
Posted on: 04 May 2014 by Fretfan
Try deleting both the upnp cache and then the image cache in nstream.  This always makes the performance more snappier !
Posted on: 04 May 2014 by Hook
+1.  Just clearing the UPnP cache has always worked for me.
ATB.
Hook
No.  Not an iOS7 issue.
Deleting the caches did the trick.  Thanks.
