Weird N-Stream problem
Posted by: Jota on 05 May 2014
Hi.
Having a strange issue with N-Stream.  I can select an album via N-Stream, click play and it starts playing but N-Stream says 'connecting...' in the window where you usually get the track playing and album art and, even more strangely although the first track of the album plays I can't go to the next track.
Click 'info' and it says 'no track playing' even though there is a track.
Posted on: 05 May 2014 by GerryMcg
I had a similar issue last week, re-booting the server corrected it.
Gerry
Posted on: 05 May 2014 by hungryhalibut
When this happens to me, I switch the SuperUniti off then on, and music is restored. It's easier than rebooting the server, so worth trying first.
Posted on: 05 May 2014 by Jota
Thanks guys.  I took the easy option first and restarted the UQ2 and that sorted it!
Posted on: 05 May 2014 by Bart
This does happen occasionally to me; I also find the better cure to switch off and back on the player.  I think it happens if I reboot the server but not the player.  I've never fixed the IP address of the player and this could have SOMETHING to do with it.  But those are the exact symptoms; only the first track of the selected album plays, and nStream continues to say only "connecting."
