Sonos and DAC V1
Posted by: BillK on 08 May 2014
How would a Connect work with a V1? Anyone using this?
Posted on: 11 May 2014 by sjw
yes into 202/200 ovator400
I use a wire world optical between the two.
I'm really pleased with it.
It really is very good and the best bit is the sonos software and spotify integration.
I did have a linn ds for a while and sold it - the software fell over a lot with airplay. It might have been my network but even with lots of tinkering and it kept doing so.
I found that sonos and the V1 dac is very stable,sounds really good and is a doodle to use. I really don't care what a server is at all.
I also decided that there are going to be many more changes in digital music and as time goes on i could change the sonos as a player for something else
Posted on: 11 May 2014 by BillK
Thanks for your reply, I thought no one was using this!
What I would like to do is use Spotify only from my Nexus 7 Android, into the Connect and then to the V1, with no PC at all, is this possible?
i've added spotify to the sonos
all control is via iPad
an apple use so i know nothing about windows or android!
