Superuniti "wired" option
Posted by: Richard walker on 13 May 2014
Hi. Set up my new superuniti and it works fine over wireless - my music is on a synology NAS. All the forums suggest it is "better" to hard wire i.e. to directly connect, but I can't do this because the internet and and router are in another room. OK so the questions.
Best- means sound? or no drop outs? (which I don't have)
If best means sound- what do I need next to the SU? a LAN switch ? The synology has a wireless usb stick in the rear.
There is no schematic design with the set up book and so I am slightly lost. Couldn't find anything on the forum or internet. Am using n stream to control the unit.
