HDX and JRiver MediaCenter as a network player
Posted by: Eugene on 18 May 2014
I use HDX as a server and I am not able to playback files on JRiver MC 19 on my Mac. I see Naim HDX Server in the list of libraries of JRiver but when I try to load an HDX library I get a message "There was a problem retrieving files from the selected DLNA Server. Please ensure that the server you are connecting to supports search, and that it is running properly. Your library may be incomplete until you correct the problem and reload the library". It seems strange as Naim works properly with other devices (e.g. AV receiver and PS3).
Posted on: 21 May 2014 by Eugene
As there is no respond probably no one have met the same problem. So I will try to ask the question in a different way. Does anyone use JRiver of any version on any platform as a player with HDX as a server? Is it possible at all?
