NDX-SN2 input changes
Posted by: rded on 23 May 2014
Hi All,
I have the NDX Connected to SN2/HC2 and use the n-stream app to control volume and inputs. However, every time I switch from UPnP to iRadio and vice versa, the Supernait's input switches from CD to the one on the far right. Is there a way to fix this? Thanks
Posted on: 23 May 2014 by sjbabbey
I assume you're using system automation. If so it looks like it is set up as having the default preamp input set for the streamer. You need to go into your settings menu/system automation in your NDX and change the Preamp setting for the streamer to Pre CD or whichever input you're using on the SN2.
Posted on: 23 May 2014 by GraemeH
https://forums.naimaudio.com/to...n2-input-help-please
Posted on: 25 May 2014 by rded
It's fixed now. Thank you all so much!
