S/PDIF electrical to DAC: which cable ?
Posted by: nbpf on 26 May 2014
I am testing a s/h Naim DAC into my SN2. Source is a fit-pc3 with electrical 3.5mm S/PDIF output.
The standard cable supplied with the the fit-pc3 works fine when connected to one of the two coaxial RCA input ports of the DAC.
I have tried Oehlbach NF 113 Digital (coaxial, 3.5mm jack to RCA, 75 ohms HF impedance, see http://www.oehlbach.com/en/com...r/audio/cable/nf-113 for details) on the same DAC port but it does not appear to work. I do not know if this is a fit-pc3 or a DAC incompatibility.
Any suggestion for a reasonably priced coaxial, 3.5mm jack to RCA cable to connect to the Naim DAC via electrical S/PDIF ?
Posted on: 27 May 2014 by james n
I'd stick with the standard cable if that works ok and think about getting an external USB to S/PDIF converter.
A 3.5mm connector is not really suited well to this application.
Posted on: 27 May 2014 by nbpf
Thanks James, any recommendation for a USB to S/PDIF converter ? What about M2Tech Hiface 2 or M2Tech Evo ? Thanks, nbpf
Posted on: 27 May 2014 by PinkHamster
If you're only testing the s/h Naim DAC, I'd rather skip it and go for a USB capable DAC instead. Fitting in a USB to S/PDIF converter would be too much of a compromise.
But what interests me more is the incompatability of the NF113. This implies that either the cable, or the PC or the DAC are not according to the specs.
I am comparing the Naim DAC to my portable M2Tech Hiface DAC. Although the M2Tech is very good, in particular when considering its size and price, I find the Naim DAC better. Why do you believe a USB to S/PDIF converter would be a compromise ? Which USB DAC would you suggest as alternative to the Naim DAC ?
Right, I suspect the fit-pc3 3.5 S/PDIF port is incompatible with the NF 113's jack. Another problem with the S/PDIF port is that, while the sound card of the fit-pc3 works flawlessly with 44.1, 48, 96 and 192 kHz 16 and 24 bit files, it sounds very bad with 88.2 kHz 24 bit files (both FLAC and WAV). Also, I can hear distinct echoes when playing the 88.2 kHz High Definition Frequency Sweep test file from
http://www.audiocheck.net/test...hdefinitionaudio.php
through S/PDIF port of the fit-pc3 into the Naim NAC. On the other hand, the same file sounds fine when played by the Naim DAC from a USB Stick.
Ahhh, it's just that I like to have things simple and straight forward. So if I intended to go out of my PC via USB, I would just not even think of buying a DAC which cannot deal with USB natively. But that's just me.
As for other DACs ... there are so many out there. I really don't know. The only thing I know is that with modern DACs there are hardly any SQ differences any more. I find this to be true even across the whole range of price levels. Threre are certainly exceptions, but only of the negative kind, where you have a badly designed product. Some DACs may also have different emphasises, but hardly none are really bad.
