m2Tech DAC Young.
Posted by: DHT on 27 February 2011
I have been trying one of the new M2tech young dacs in my second system, at the moment I am using an EVO into my Audio Synthesid DAC, but the young is really good ,plugs straight into my Mac mini, I am very impressed with it, and one box neater too.
H
H
Posted on: 27 February 2011 by Tog
Almost matches the Mini - love to hear one up against the nDac - did I say that out loud - cripes I will have to leave town now. Italian so the first batch will have bits that drop off Alfa like...
Tog
Tog
Posted on: 27 February 2011 by DHT
Apparently the first batch had a problem in their firmware, sorted now, I am going to keep theYoung, when I get a chance I will compare it to the Weiss which is in the front room.
Posted on: 27 February 2011 by Rosewind
DHT.
That is going to be an interesting comparison. The M2Tech Young v2 has arrived in the UK as we write. I know that some good people will compare it to the Rega DAC and other DACs quite soon. I am also keen on hearing about extended hands-on experiences with the NDX.
Best wishes,
Peter
Best wishes,
Peter
Posted on: 27 February 2011 by MontyMusic
I got my v2 Young yesterday. All the problems encountered with the first batch seem to be sorted. It's a great DAC and well worth an audition if using a computer as a source.
I've also tried the Young with a friends Micromega transport and it also sounded great. A great value DAC and future ready.....
I have had a quick listen to both dacs with my ATC's and maybe the Weiss has a tiny bit better separation perhaps you hear a bit more low level stuff but there isn't a huge difference.
The Weiss is more convenient with the remote though, the Young is a superb little thing, I read that someone is making a power supply for it, if it's not too expensive I might give that a whirl.
H
H
Posted on: 27 February 2011 by AMA
DHT, what Weiss you have?
202
So, 1500 $ M2tech young dac sounds very close in SQ to 6500 $ Weiss DAC202?
I guess the high class external PS will take it even closer...
I think grand companies like Weiss/Naim should take lessons from Italy how to design low cost and high performance dacs
DHT, did you have a chance to compare USB-stick->nDAC against PC-USB->young dac?
Posted on: 28 February 2011 by DHT
Ama Hi, I compared Naim versus Weiss dacII and preferred the Weiss, when the 202 was released I thought it sounded better than the dacII and the remote is useful.
The Little M2Tech is extremely good though, I will try a proper external power supply with it and I believe there is going to be a Lithium Ion option.
Posted on: 28 February 2011 by Tog
High quality DAC design does not necessarily rely on high cost implementations - it looks good too.
Tog
Tog
I agree it appears that dacs ( some anyway) are better and cheaper than ever, which has to be good.
Posted on: 12 March 2011 by Davidr
Has anyone done a comparisons with the Benchmark DAC1?
Posted on: 12 March 2011 by Tog
Thses dacs are designed from a slightly different angle than the nDac but the sound quality only has to get very close to make the vfm irresistible.
Tog
Tog
I have a mini mac, a benchmark dac1, 52 and 2x135's on a fraim, all in a different room to the sonus faber electra amator II's. I have just moved the components to a different room and repositioned the speakers. I had to move the speakers around to find the right position and now they sound great BUT now the sound is much more 'digital'. I am convinced that this is because the components are completely isolated and I am hearing an improvement to the system which is highlighting some source inadequacies. So I was wondering if a nDac would solve the problem?
Posted on: 12 March 2011 by Mr Underhill
David,
I did comparisons with the BM DAC1. Is the nDAC better? Maybe, probably ...a bit.
Did I change? Yes, I wanted the digital hub aspect - multiple devices plugged through the one box.
BUT, I do use EAR amps, and I know that Naim amplification will vary what I heard.
When I initially auditioned the nDAC I took the BM with me. It was interesting listening to the BM in that context, and I could understand some of the negative comments I have read by other people.
Ultimately you'll need to have a listen in your system.
M
M
Posted on: 12 March 2011 by js
You'll need to try for yourself. I think this difference isn't subtle but there's so many variables with DIG that ymmv..
Posted on: 13 March 2011 by Davidr
Thanks.
JS please could you elaborate on the difference that you would expect. Also I think I will need a TOSLINK splitter are these upto standard and which one would you recommend?. The reason is that that I use the mini mac for watching movies and use the optical out to a receiver for multi channel sound ( using the pre-out to the 52 for the left and right front speakers). Alternativelcould I use a record output form the 52 for the receiver?
Posted on: 13 March 2011 by js
Thanks.
More info/music, less analytical or cool with the Naims. JS please could you elaborate on the difference that you would expect. Also I think I will need a TOSLINK splitter are these upto standard and which one would you recommend?. The reason is that that I use the mini mac for watching movies and use the optical out to a receiver for multi channel sound ( using the pre-out to the 52 for the left and right front speakers). Alternativelcould I use a record output form the 52 for the receiver?
Considering your system and files, I would actually recommend the NDX if budget will allow. Removes what I think is a reasonably significant computer player and output part of the interface. You're seeing more of the members here moving to streaming or a purpose built dedicated local storage player all the time. I feel they're making good choices. YMMV
JS. Beyond my budget I am afraid.
So do I need a TOSLINK splitter? Or can I use the record output from the 52?
Posted on: 08 April 2011 by totemphile
So has anyone compared the Young DAC v.2 with the nDAC then?
Posted on: 08 April 2011 by JBGood
DAC Young vs Bryston BDA-1? I would love to hear from anybody who gets the chance to do this comparison.
JB
