nStream & some minor frustrations
Posted by: Mike-B on 29 May 2014
I was idling away last evening playing at fixing some problems with nStream.
Two issues, nothing like show stoppers, just nuisance stuff.
Does anyone have fixes or know if the next version of nStream will fix it (& when) etc
I get the wrong album “book” with a few recordings – I can select the correct album via the “Not This Album?” button feature & it sticks but only as long as the album is playing, it doesn't stick with that album after another album is selected & I cannot find a way to get it to do so – any ideas?.
On a few - & I mean a few – albums I have some tracks with one line of song title not showing.
It shows up perfectly with UPnP Compatibility Mode enabled,  not when the preferred & user friendly UPnP Compatibility Mode is disabled.
Posted on: 29 May 2014 by osprey
For the first issue I don't have any comments but the second one I have experienced when the song title contains non standard characters or in my case any of the Scandinavian specialities. This however seems to be an UPnP server specific issue since I have had it with ReadyDLNA (but Asset works fine).
