Unitiserve as UPnP Server -- several questions
Posted by: Gene on 02 June 2014
I discovered Naim about a year ago, and since then acquired two players -- NDX and Unitiquite 2. Both work pretty well, so I was looking for a decent UPnP server to stream my files stored on a Synology Rackstation. I tried virtually every type of the software DLNA and UPnP server available, and settled for two -- Asset (running on dedicated Raspberry Pi box) and Minimserver running on Synology itself. Unfortunately, both had some drawbacks, so at the end, being very confident, that Naim knows better how to do things, I decided that Unitiserve would be the best solution to stream music to my two Naim players, plus feed another stream locally (to my outdoor sound system).
When I installed the Unitiserve, I discovered several issues, which rendered Unitiserver practically useless in my case. maybe I just don't understand the ways things should be done, so expert advices would be highly appreciated.
1. No Unicode support. I have a bunch (several hundred) albums which have Russian tags (in Unicode). I spent several years carefully converting the tags into correct encoding, and finally I could play all of them on all my devices (Unicode support for Naim players was added in 2010). But Unitiserve doesn't handle Unicode tags a all.
2. I can not point Unitiserve to the right directory on my NAS. It scans every folder on shared drive. If there are several shared folders, then one can deactivate some shared folders, but I couldn't find the way to force Unitiserve to look only at specific directory within the shared folder. I have ton of other "music" files in the same shared folder which I do not want to be included in my library. All the other UPnP servers allow to select a directory, Unitiserve does not.I created a separate share and put a link to my desired music directory there (in Windows world it is known as "shortcut"). Unitiserve can't follow the link.
3. Not all my collection have proper tags (yet). All the other UPnP servers allow to find music browsing folders/files. I can't find the way to do so with Unitiserve
4. (not a show stopper, just curious). It was stated that Unitiserve can send 6 "n-streams" to compatible devices. I think that both NDX and Unitiserve are compatible. But in the "Zone maintenance" menu of the Naim Desktop Client there is only one zone (local sound card), and the "Add" button greyed out.
5. When I browsing music by "album", each combination album/artist is shown as a separate "album". Kinda annoying.
Overall, I like Naim equipment, in it would be a shame to dump the server because of these troubles. Maybe I just missing something? But in any case, I will not "translate" the Unicode tags, move the terabytes of my music into different folders... Positive uggestions how to deal with these troubles are highly appreciated.
