HDX DTC problem
Posted by: meissmar on 11 June 2014
With the latest version of the DTC 1.7, I can not seem to get the right hand window that shows all the titles of an album and where I can edit them. With the old 1.6, the window is showing. I have tried everything I can think of and it does not seem that there are two windows or tabs inside the application window.
Is it me or my PC who does not "get it" or is this a general "feature" of the new version? Like this, I can not edit any track titles or delete individual tracks. And with the old version when opening, I always get a popup recommending to use the new version for compatibility reasons.
Can anybody help me?
Mario
Posted on: 11 June 2014 by Claus-Thoegersen
Have you tried to selec player & maintenance mode in the view menu?
Claus
Posted on: 11 June 2014 by meissmar
I have done that, yes.
When selecting player mode, I only get the small window on top which shows tracks playing, cover etc.
In maintenance mode, I get the bigger windows, but as I said the detail window on the right is missing.
But the 3. mode player and maintenence did you try that?
There has been 2 other threads on this in the last 2 months, for one user the problem was that the Win7 firewall wants to block dtc, and you need to give it permission to get through the firewall.
This will normally come up when you first run the dtc and if you give the wrong anser this could be the problem.
Claus
Posted on: 23 June 2014 by meissmar
I've tried all that. Didn't help.
The funny thing is that after installing the older version of DTC and uninstalling it to play with the new version again, something has changed in the system. Because now the window is there. Seems like something remaind in the registry from the installation of the older version and now it's fine.
Anyway, thanks for trying to help!
Posted on: 23 June 2014 by Klout10
Always uninstall the old version of DTC before installing the new one.
Glad everything works fine now!
Michel
Posted on: 23 June 2014 by Paul Quigley ie
run regedit / V
File Export and save your settings in case anything goes wrong.
Select my computer.
Edit Find DigiFi
Select DigiFi.Desktop.Ui
Select MusicLibarySplit
right click Modify
enter the value f9
Ok
exit
now start NDC
Posted on: 03 July 2014 by meissmar
For whatever reason it did not work again today on my laptop.
So I tried editing the registry and it works!
Great help! Thanks alot!
Mario
