Naim HDX AC In
Posted by: Eugene on 16 June 2014
The Power in Socket of NAIM HDX is somewhat movable. Is it normal?
Posted on: 16 June 2014 by james n
Yes - but by a small amount. It's a Naim 'decoupling' feature found on most of their products. If it's very loose then get it checked.
Posted on: 16 June 2014 by Jason
Mine is the same.  The socket is combined with the power switch and so noticeable when it is turned on/off.  A dealer has checked mine and he too thought it was very loose but just haven't got round to doing anything about it as it means sending it back.  While it's not a problem, I'm not sure I'll risk the courier journey for that alone.
