LED lighting and Networks
Posted by: james n on 16 June 2014
Just an observation which may help others having strange Wi-Fi and wired network problems, especially as LED lighting is becoming more prevalent .
We'd taken advantage of the in-room Wi-Fi in the hotel on a recent holiday. I noticed it would go from being very fast to extremely slow - especially after dark and initially thought it was due to increased usage over a limited bandwidth connection. After a day or two of this behaviour, i'd happened to switch off one of the lighting bars above a mirror in the room and found the Wi-Fi improved. Switching back on killed it again - the signal strength dropped quite considerably too. After taking off the diffuser panel on the light, i found four LED lighting modules inside - all except one were marked with a CE label. With the non CE module removed Wi-Fi was fine but as soon as i put the non CE marked one back in, it killed the Wi-Fi. It looked the same, worked just as well from the light output but must have been radiating quite a lot of crap out via the mains wiring over quite a wide bandwidth. It seems that some LED bulbs, especially very cheap copies leave out the suppression network for the switching LED driver so you end up with a nice little transmitter, its effectiveness in this role depending on mains wiring length and routing. CE marking is also not a guarantee that it's OK, given the number of cheap alternatives coming from the Far East.
So if you are having strange problems with Wi-Fi or Homeplugs (let's not go there on crap on the mains), it might be worth checking your LED lights aren't the issue.
James
