N-serve for iPad
Posted by: MDM on 06 March 2011
Any news on the probability and timing of Naim launching an n-serve (or otter HDX App) for iPad? Any chance of Naim finally enabling HDX owners to use the built-in vTuner to listen to internet radio (which is apparently already possible for those who use the Songbook Naim App)?
Posted on: 06 March 2011 by Paul Stephenson
Nstream iPad I would think during this month, Nserve iPad app following month with iradio on hdx
May/June if all goes well.
Posted on: 06 March 2011 by MDM
Thanks for the quick reply. I do hope that the tentative timeline that you mentioned will be met so that we will at least have the iradio functionality on the hdx before the summer. I had almost given up on it so I am glad to hear from you that it is finaly coming. After several years of patience another couple of months will not make the difference I guess ;-).
Posted on: 06 March 2011 by Klout10
Hi Paul,
That's great news, thank you for sharing that with us!
Michel
Michel
Posted on: 07 March 2011 by Pepe68
I thought the existing n-serve App is usable with an ipad (?). Do you talk about a totally new app or a cost-free update?
Posted on: 07 March 2011 by Klout10
Most iPhone/iPod Touch apps will run on the iPad in some form or another. The n-Serve and n-Stream apps are also compatible in 2x scaled mode with the iPad. FWIW, I assume Paul means a dedicated version of the apps which make use of the larger screen of the iPad and probably some added functionality. I have no idea weather it will be an update free of charge ...
Michel
Michel
Hi Paul,
can you give some details? Is the planned App a separate new one? As I get my ipad tomorrow, I don“t want to buy two apps.
Posted on: 08 March 2011 by TJ
Hi,
The app will be a free upgrade to the existing n-Serve app so if you purchase the current version you will be automatically updated to the iPhone/iPad universal version when it is released
As for new features to expect in n-Serve I added a bit more info in this thread:
https://forums.naimaudio.com/di...8285647290243/page/2
"This iPad app really is coming along nicely, as well as adding coverart support and search feature we have snuck a couple more goodies in. The app will work in offline mode which effectively means that it caches all the album and artist data locally, so if you find yourself in a record shop trying to remember if you already have a copy of that special edition Status Quo boxset you can refer to the n-Serve app on your iPhone/iPad to search your entire music collection. We have also added nice click-throughs on the extended metadata for each album and track, so you can say, view the info for a track, click on the composer to see all the albums by the composer then add them to the current playlist, then select a performer etc etc. You won't be seeing playlist and metadata editing in the first iPad release but this is something we want to press on with soon after."
Tom
Naim R&D
Tom
Naim R&D
Posted on: 08 March 2011 by Klout10
Hi Tom,
You forgot to mention iRadio for the HDX as Paul did above. Will this be available with the updated app, and/or does this requires a software update for the HDX as well??
Michel
Michel
Posted on: 08 March 2011 by Paul Stephenson
Michel this will require an hdx update once iradio is signed off.
Hi Paul,
Thank you for your quick reply. Will this be a major software update for the HDX just as the 1.5a update about a year ago? Will it be possible for end-users to install this update themselves?
Michel
Michel
Posted on: 07 June 2011 by Klout10
Any news on the iRadio update yet??
Michel
