itunes-verbatim mediashare
Posted by: u6635497341357228 on 11 March 2011
Hallo all steaming freaks.
Can anyone write down how I make Itunes- verbatim mediashare-uniti and n- steam on my iphone work together?
Please cut it out for me, i´m not that good with pc things and steaming.
My music is in acc format and stored on my pc, but i would like to store it on wav.
please help.........
Posted on: 11 March 2011 by garyi
Well your first problem is AAC.
Posted on: 11 March 2011 by pcstockton
all of the steam probably isn't helping anything either.
Posted on: 12 March 2011 by Sloop John B
Ah I see the welcoming Naim forum hasn't dissipated with new design.
I think you need to elucidate your problem a little bit more clearly Morrison in order for anyone to be able to help.
Posted on: 12 March 2011 by Phil Harris
Hi Morrison,
You have several distinct and separate bits of kit there and just asking "how do I make it all work" is a bit of a big bite do do in one hit - your dealer should also be helping you with this...
Is your iPhone connected to your wireless network?
Is your Uniti connected to your network (ideally wired) and does it work properly? Does Internet Radio work?
Does n-Stream on your iPhone find your Uniti? Does it control it?
Is your MediaShare attached to your network? Does the Uniti see it as a UPnP server? Can you select it as a source? (As far as I am aware we have not tested the MediaShare as working with the Uniti so I can only assume at this stage that it will work...)
Do you have any music on the MediaShare? Does that show up when you browse the UPnP music? Does the MediaShare have the ability to scan a remote location (your iTunes folder) for source material? Does it support AAC files as source material?
Phil
Phil
Posted on: 14 March 2011 by u6635497341357228
Well thanks for your replyes
Every things is working fin. My problem now is moving itunes on to my Verbatim. I would like
to change my music from acc to wav. Should I re-rip it all in wav and can I store it directly onto
my Verbatim. I have not space for about 400 CD on my PC in wav. And what about cover art.
I have tryed to copy my music onto the Verbatim and it all shows up in right order with cover art
and I can steam it all on my uniti but when I use n-steam most of the cover art is missing.
I have talked with my dealer but I think this new world is a bite too new
Thanks Morrison
Thanks Morrison
Posted on: 14 March 2011 by garyi
A few things:
1. You need to re rip the cds, if you convert AAC to WAV it will still sound crap.
2. iTunes does not treat image files like most other programs, in order to see the cover art you will either need to use some sort of programme or manually find the covers from google and put them in the same folder as the music and change the name to 'folder.jpg'. If you are on a PC then something like ember media manager can help with the artwork.
All images need to be in jpg format and 300x300 is fine, too large and its un-necessery bandwidth.
Posted on: 15 March 2011 by u6635497341357228
If I must re rip All my cd should I use another rippingtool then iTunes.
I would Like to keep my acc stored musik for use on my iPod.
What tool must I use to rip my new wav Music onto my nas.
Posted on: 15 March 2011 by David
Morrison
many people here use dbpoweramp cd ripper.
