N-Stream doesn't see UPnP server, needs ND5XS reboot to come back
Posted by: ricsimas on 04 July 2014
Hi everyone,
After periods of inactivity (where everything is kept turned on), N-Stream can't find the server for whatever reason. If I reboot the ND5, it gives me a no-network error message very often (despite being the only device plugged into that switch that has issues - even when I swap cables).
Eventually after rebooting everything a couple of times it will work, but this does not seem right to me. Everything else works, and other UPnP devices can see the Asset server (running on a Windows 7 machine 24/7).
Any suggestions? I've played with different cables to rule that out.
