Which AP support N-Stream without using UPnP compatability mode
Posted by: AYLW on 09 July 2014
I have spent lots of time trying to figure out how to make N-Stream work without the need to turn on UPnP compatability mode. It is so convenient to be able to create playlists and queue up the song you want to listen. I cannot get my QNAP NAS running Twonky or Asset to work properly without running in UPnP compatability mode. My dealer told me that a Synology NAS running Media Server will be able to run in "Normal mode", so I bought one just for this purpose. To my suprise, it did not work out! It still need to run in UPnP compatability mode
. So, what's left in my system that is different from my dealer's system is the wireless router arrangement. I am using a Buffalo wireless router at home but I am not using it's wifi connection with the iPad because it's located far away from the living room. I have 2 wired connection installed at the living room, so I used one for the NDX and the other for a small Access Point to provide wifi connection for the iPad. I have tried TP-LINK TL-WR710N and EagleTec Nano Travel Router and use it as an AP but both need to run in UPnP compatability mode. Today I tried to sit near the Buffalo wireless router and connect the iPad to it's wifi connectiom and bingo! It is able to run in "Normal mode". So now I need to find an AP that will work properly in "Normal mode". I do not know what specifications to look for when I source for this AP, can someone give me some idea? I prefer to get one that is small in size. Thank you!
