Problem with NDX with Usb
Posted by: Tariqv on 15 July 2014
Hi All,
i have an NDX which I am currently using to listen from flac files through a flash disc (64gb) connected to the front panel USb input. while listening to music the playback suddenly stops without any apparent reason. Also on occasions when I try torestart the song after this happens, the NDX freezes alltogether, unable to play any kind of source.
does anyone experience a similar issue? What is the reason, may the culprit be my flash drive?
Posted on: 15 July 2014 by Simon-in-Suffolk
Try a different make/size of memory stick. It might be you have found a compatibility issue.
