nStream wish: album collections
Posted by: charlesphoto on 24 July 2014
One thing I would love to see in a future version of nStream is the ability to make collections by lp. Sort of a 'smart collection' idea. Quite often I would like to group certain albums (say for late night listening, rocking out, etc etc) versus making playlists of certain songs. I think this would be pretty easy to do. It would also mitigate the need to have exacting genre metatags if one could group them as one wished for easy access depending on mood, etc.
Also would love to see a way to rate songs/albums, better tree navigation, ability to see both song and artist on album view (good for comps), and I'm sure a couple more I just can't think of at the moment.
Anyone else like the idea of album collections?
In effect it would mean adding a user defined 'collection' to the existing 'genre', which may or may not be possible. I've added, for example, an ECM genre to keep them all together, and Vocal Jazz to keep the singers separate. Otherwise it all ends up in a big jazz ragbag. I find genre is really useful, if a little arbitrary at times.
The feature I'd like most is to be able to browse the album collection while listening to the radio. As it stands, as soon as one switches to upnp to view the albums, everything goes silent. It's daft.
+1
As you have the Unitiserve, close nStream then open nServe to browse albums.
Thanks Jan - that's what I do, but it's still a faff, and most nStream users probably don't have a Naim server. What would be good is a separate search facility, where you could find the album you want, while the radio is playing, and then when you hit play, the input switches from radio to upnp.
Charlesphoto - I believe what you are requesting can be done by the UPnP server. Indeed this is what I do with Asset - using its 'dynamic playlist' function. I can select albums that meet certain criteria, by using NStream, and then play through them in order or randomly. Seem to work well and I use dynamic playlist probably more than any other access method on my streaming setup.
Although the above does require the use of meta tags of some description to select on. But then to my mind that was a key function of the meta tags.
The alternate I sometimes do is select multiple albums into a NStream playlist by pressing and pausing on the album name - that work well - but is limited by the Naim playlist streaming size. These playlists are kept on NStream and then uploaded to the player.
Simon
In the prototype of the new NStream - I am sure I saw this a new feature at a recent Naim event.
Anyone who was at the Open Day at Hi-Fi Lounge yesterday, you heard the Muso, did anyone have a fiddle with the new App to control it? And if so, any comments in regard to the above?
I guess it must nearly be the finished version if Muso is launching in September....
Thanks Simon, that would be good indeed. Full integration with the Nespresso machine would be good too.
Simon
That's why I have a separate tuner connected to the input labelled 'Tuner', next to streamer on my preamp. So left button = UPNP streamer, right button = tuner. OK, so I have to use the remote rather than n-stream to switch, but no big deal for me, and the convenience of having 'instant on' for my favourite radio station is very satisfying.
But Naim, don't let my opinion stop you developing this n-stream facility, although you're probably like me, wondering how tf you would implement the switching user interface (perhaps a separate 'Play Now' button - now that would really annoy a lot of folks, me included
