Macbook Pro-Dac skipping problem±
Posted by: Jamesw1 on 25 July 2014
Hi all,
I hope someone can help.
On the whole i am really pleased with my home set-up at the moment. I have a 2013 Macbook Pro and a Chord Chordette QuteHd, which sounds really wonderful. Quite a lot better than my old Naim CD5i it has to be said! These are linked with the supplied usb cable from Chord. and is then fed to my Naim amps via a Chord Cobra.
I do have one issue though...On certain tracks i get popping, crackling and skipping noises on an intermittent basis, i.e. i can listen to a track one day and it doesn't skip then all of a sudden it starts again!
I try restarting the track and sometimes that cures it but it is hardly ideal. It is like the dac is struggling with something...Playing through the internal Mac speakers there are no issues at all.
Has anyone else on this wonderful forum had a similar issue? if so what has been done about it?
All music is in AIFF, has been ripped with EAC, and I'm using iTunes.
Thanks!
James
Posted on: 25 July 2014 by winkyincanada
I'm thinking that it is perhaps a driver issue. Have you checked with Chord that you have latest driver for your DAC?
Otherwise check that the Macbook isin't busy trying to do stuff in the background. Look at the activity monitor for any processes that might be hogging the cpu or memory. Check your console log for weird stuff going on, too. Audio processing is pretty trivial for modern computers, but if it is given very low priority compared to other things, your computer could still be pausing it to get on with what it thinks are more important tasks.
Posted on: 25 July 2014 by Jan-Erik Nordoen
As winky says, the MBP background processes can cause this. I strongly recommend installing Audirvana+. Run it in hog-mode and your problems should disappear. You can run it solo or integrated with iTunes, and you can trial it before buying. The greatest gain though will be in sound quality ; it is very good.
Jan
Posted on: 25 July 2014 by garyi
I would push audio through something like bitperfect. 6 quid on the app store.
BitPerfect is a very good in iTunes. But (if I'm not mistaken) it doesn't disable Spotlight, Time Machine and Detection of iDevices on USB, which Audirvana does (Hog Mode, sort of).
Jan
Posted on: 25 July 2014 by tonym
Audirvana+ is excellent. I currently use Amarra because it can be used with iRC room correction software (which is the biggest single upgrade I think I've made recently). This has an inbuilt buffer; maybe Audirvana does too? A buffer certainly helps avoid problems with computer processes interfering with music delivery.
Posted on: 25 July 2014 by Steve J
Another vote for Audirvana+. It works very well indeed.
Posted on: 25 July 2014 by Jude2012
+2
Audivarna Plus has great SQ and is a well thought though piece of software for working around the issues in Mac OS regarding audio.
If you decide to trial it, I wold recommend allocating as much  RAM to AV+ which doesn't cause Mac OS to use memory swaps (Activity Viewsr will show whether memory swaps are being used).  In this way Mac OS can go about it's other essential tasks with the remaining unhogged RAM without needing to use the HDD or SSD to make up the shortfall.
I would also use Disk Utility on the MBP to check and repair the HDD/SSD a well as permissions straight away as this may resolve your current issue.  Ideally you would do this from the Mac OS Recovery Partition (Command R when're starting the. MBP.
HTH
Jude
The memory 'load' may be the reason for the skipping and is the reason I use a dedicated MacMini for the iTunes/ Audirvarna only. No other software, email, Time Machine etc.
I've never got even a 5 year old mini to skip on a dac, even with Plex and Transmission running in the background.
Its not a memory load issues what ever it is. I fancy the dac.
Agree that it is something to do with the MBP or the DAC.
The easiest check would be to use try another  Mac and see if the issue  is still there.
If this not possible, I would check that the MBP's Mac OS is working OK (doing a basic check of  the file system as mentioned earlier is good enough for that), assuming that it is a fairly standard configuration/set up of the MBP.
If the issue still persists then it could be a hardware issue on the MBP ( a local Apple store or authorised reseller could do this for you).  If the issue still exists it's the DAC.
As @ Wat infers it would also be good to know more about the precise set up of the MBP.
J
Posted on: 26 July 2014 by Jamesw1
Thanks so much for your input guys...much appreciated!
Audirvana sounds like the way to go from what you have sad, however what I don't understand is that...the mbp is playing the music seamlessly through its own speakers using iTunes, so surely the issue is with the dac?
I don't know much about this kind of thing admittedly, but that seems logical to me.
With regards to cleaning the hdd..the laptop is only 7 months old and everything is on an external hd including the music so
I don't think that would be an issue...
Posted on: 26 July 2014 by winkyincanada
Jan
Yeah, the Hog mode on BitPerfect isn't too intrusive. I'd recommend BP. Cheaper than the others.
Posted on: 26 July 2014 by Jude2012
The hog mode in AV+ is only used when it is playing a track, so unless one is using a Mac for non music tasks there's no issue.
Also does Bitpetfect make sue of Core Audio or something else?
J
Posted on: 26 July 2014 by Drew Turner
Audirvana sounded great but  it skipped constantly . Finally gave up
Posted on: 28 July 2014 by Jamesw1
Thanks all for your comments and advice..Ive been away for the weekend so haven't had a chance to explore possible cures yet but hopefully will be able to tonight!
James
Posted on: 06 August 2014 by Jamesw1
Hi again,
It has been a few days now after i have installed Bitperfect, and alas this has not helped my issue. i still get sporadic crackling/skipping/music stopping. It is so annoying! Listened to Billy Joel last night..A particular song skipped, so i started it again and it stopped skipping...i liken it to a scratched cd...It will only happen every now and again..Maybe one in every 8-10 songs.
I can't understand it...I have a high end dad (relatively speaking), a high end macbook and am connecting it with its advised connector (supplied usb cabe) and i am still having issues!
As mentioned before..All files are Aiff and i am using iTunes with Bitperfect in the background.
Can anyone help? Is there anything else i can use other than usb that will sound as good and eliminate this issue?
Thanks!
James
Posted on: 06 August 2014 by Adrian F.
Are there any other USB devices connected besides the DAC?
Yes but only my external hd I use to store my music.
James
Posted on: 06 August 2014 by winkyincanada
James
Might be the externald drive or the connecting bus. Try copying some of your music to the local drive on the MacBook and play it from there. See if that helps.
Hi, thanks for the suggestion but I have tried that as well as another hard drive but it hasn't helped.
Tried Audirvana plus and that hasn't helped either.
I'm running out of patience and options here...I'm going to try my partners cheapy windows laptop and see whether that helps.
James
James
Really strange. Have you tried a full re-install of iTunes? What about the OS?
Posted on: 06 August 2014 by garyi
I wouldn't be fingering the mac here. Does the dac work with other things?
Posted on: 06 August 2014 by NickSeattle
Swap the optical cable to see if there is a defect -- happens to the best of 'em.
Right...Samsung Windows laptop doing the same thing, but worse actually..i.e. more frequently.
Changed usb cable to be sure...So it has to be the Chord Dac unfortunately...Its the only thing i can think of...
Ill give them a buzz!
Thanks for the responses..
James
Hi Wat,
Yes I downloaded the windows 7 driver for the DAC.
Didn't make a difference unfortunately!
