Website Audio from Macbook Air to Uniti
Posted by: THARE on 27 July 2014
Hi - is there a way to play audio from a website on my macbook through my uniti, wirelessly? a bit like twonky beam...cheers Tim
airport express
Airplay to an Airport Express is the first thing I thought of. Or you could use a Bluetooth solution.
Struggling to see a bluetooth solution, but perhaps. Express is the way to go if you have IOS, not sure whats out there for PC/Android affairs.
Gary, something like the Rocketfish bluetooth receiver would work I believe. Pair it to the Macbook. Output options from the Rocketfish include digital (optical) and analog (I think it's a mini headphone connector, but an adaptor to provide RCA L and R leads is included. It may well sound 'good enough' for relatively lossy source material, and it's cheap comparitively.
so presumably the op would then need a computer at the qute end, you might need to mention that ![]()
Thanks for you're posts, i'm going for airport express into the back of my uniti and then i've found this software for the mac, airfoil (http://www.rogueamoeba.com/airfoil/mac/). I haven't tried it all yet, i'll report back. Cheers Tim
Airfoil worked OK for me
No just a Macbook which he owns, as the bluetooth (or AirPlay) sender, and a Rocketfish (or Airport Express) at the Uniti end.
