New dsd announced soon by NAIM
Posted by: Yves on 05 August 2014
New compatible product dsd will be announced soon
Are you speculating or do you actually have something new to add (since all your previous posts seem to say the same...)
Said the same thing a little over a year ago. He'll be right eventually. Or not.
Sorry was going to post on this, but porker just did a swallow dive past my window and distracted me.
Last year my interest would have sparked, but now I'm all DAC'd out and DSD is a format my DAC eats for breakfast. So smoke me a kipper, skipper: I'm off to play another great DSD album.
DSD, what a format!
Decidedly Superior Digital from the Planet Oa.
Amazing you should be saying this, with Roger Waters singing Pigs On The Wing as I write - from the Equator...
Piggy's going places isn't he?
DSD, what a format!
"DSD, what a format!"
+1
Wat how are you sourcing your DSD albums -- purchasing digital downloads? Is this all new music, or are you backfilling as well?
This DSD/DXD malarkey has me totally confused. if I bought a compatible DAC, where the hell would I find any Music? It seems I need to befriend a first generation PS3 owner to join in the fun!
Keith
Envoyé de mon iPad
> Le 2014-08-05 à 13:18, Naim Audio Forums <alerts@hoop.la> a écrit :
Envoyé de mon iPad
> Le 2014-08-05 à 13:10, Naim Audio Forums <alerts@hoop.la> a écrit :
Envoyé de mon iPad
> Le 2014-08-05 à 13:26, Naim Audio Forums <alerts@hoop.la> a écrit :
If DSD/DXD becomes the latest "must have", & if it takes the high end status pricing away from the 24bit 48-96-192khz format's - bring it on !!!
Yeahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
for me the best new of the month!!!!!!!!!!!!!!!!!!!!!!!!!!!
Can i still play my CD's on it?
where is the official Naim announcement on this - I can't locate it anywhere, so where should I be looking ![]()
Stop looking Mr Frog. Yves is trying to pull one of your long legs. ![]()
... Yes, indeed, it's a new recording on SACD!
"High end" source files without the "high end status pricing" -- wishful thinking I'm afraid.
So, converting a PCM file to DSD makes it sound better?
I was wondering the same thing
If they are encoded at the same resolution, PCM FLAC and WAV and DSD all contain the same data (when they're fully decoded), so the files themselves sound the same (at least a I can't hear a difference when I look at the disk).
Your system may of course render them with different artefacts, so your system may sound different when playing them.
DSD+little "light-show-dac" made me to stop dreaming about LP12 + tons of records.
Hi Diamond Black,
Thanks for the explanation/instruction.
Keith
